S Sonnn New Member Jan 28, 2019 3 0 Wisconsin Jan 28, 2019 #1 Is it possible to use a A/B switch when you have 2 dishes ( Western & Eastern) to switch between the dishes? I understand that if possible you would have to run a check switch if you would switch between them correct? Any input would be appreciated
Jim5506 SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Oct 19, 2004 8,418 4,034 Slaton, Texas Jan 28, 2019 #2 Biggest concern would be does the switch pass the frequencies that are coming down the pipe from the Dish LNB? Dish stacks frequencies, especially on the H3, so that might be a real problem. Reactions: charlesrshell
S Sonnn New Member Jan 28, 2019 3 0 Wisconsin Jan 28, 2019 #3 I don't have any new irds but I understand your concern, That's why I asked here if its even possible
Brussam SatelliteGuys Pro Nov 30, 2006 1,337 504 Jan 28, 2019 #4 Been using a A-B Switch from toggling between the Winegard Trav'ler on the roof and a ground tripod dish for 13 years. Look for a high quality switch. Reactions: charlesrshell
Claude Greiner SatelliteGuys Master Supporting Founder Sep 8, 2003 13,213 3,776 Detroit - The Paris of the Midwest Jan 29, 2019 #5 I don't think they make any high quality A/B Switches for coax
S Sonnn New Member Jan 28, 2019 3 0 Wisconsin Jan 30, 2019 #7 Contemporary Research RF-AB RF A-B Switch, self-terminating, closure controlled 2.5 Ghz This one works great... Thanks for your input
Brussam SatelliteGuys Pro Nov 30, 2006 1,337 504 Jan 30, 2019 #8 We were talking about an A-B coax switch, not an HDMI switch, like this Eagle Switch.
Claude Greiner SatelliteGuys Master Supporting Founder Sep 8, 2003 13,213 3,776 Detroit - The Paris of the Midwest Feb 1, 2019 #9 Brussam said: We were talking about an A-B coax switch, not an HDMI switch, like this Eagle Switch. Click to expand... Yea that will likely work for passing up to 2 ghz but I would cross your fingers as they are generally rated for 900 MHz. Reactions: HiDefRev
