Am I wrong in thinking this?
J3ff
289
I thought I could watch one program, while it records another... In dual mode.?
In single mode I could record two programs and watch a third....that sounds wrong, but what exactly is the deal here?
In dual mode cant you watch a program on tv1 while recording at the same time on a different channel on tv1
In dual mode, TV1 can watch a recorded program while it records, and I believe TV2 can do the same thing. You can't watch something and record something live at the same time unless you're in Single mode.
Your last sentence is correct.
although technically true, it's not entirely true in practice, I do this all the time. Assuming that the other tuner is not in use, that is. So I'm usually on tuner 1 and I set my default tuner to record on tuner 2 so i'm almost always doing this. If for some reason I want to watch "live" whats on tuner 2, I set it to record and then simply hit the PVR button and select that show. So ii'm watching pretty close to live, then I just delete it when I'm done.
Now if you want to watch a show live on both tuners while you record something else on either, that ain't gonna happen (there's only 2 tuners...)
computer hookup to 501
1 remote - 2 satellite receivers
