It sucks that Dish won't make the TV2 SD output tolerable on modern HDTVs. :cry:
1948, not 1950s.NTSC will never look good on HDTVs. Hell that standard is from the early 1950s!
So... You never watched a DVD on an HDTV?
DVDs look fantastic on my 42" TV, better than some so-called HD channels, via component cables. And how is the MPEG video format of a DVD not NTSC? Taken down to the file, they are 720 x 480, 29.997 fps video files. How is this not NTSC?
Okay so other than the fact that the video signal conforms to NTSC standards in resolution and frame rate, refresh rate, it isn't NTSC.... gotcha. NOT! LOL!
If DVDs aren't NTSC then Dish or Direct TV SD video aren't NTSC either! Haahahaha
A well mastered dvd played on a good upscaling dvd/bd player connected via HDMI will look good, sometimes very good, especially on a smallish HDTV (42" or less). It won't look great like a bd though.My point was that NTSC (via RF which is what is mostly referred to as NTSC, as opposed to ATSC,) will never look good on HDTVs.
The way it ends up on a TV in the US is via 4x3 29.97fps. 60 Hz, 480 x 720. We can argue minutia all day, but that is NTSC.
In this case it means it is part of the NTSC system, but isn't the original system definition. That would be due to the fact that it can be either 480i or 480p. Not part of the standard or OTA version. That is what it means. I didn't feel like posting a treatise so I just took a couple of lines out of it.Argue semantics all you want but my point still stands! Also, you do realize what the word "informal" means, right?
Well the original was 240 lines. So it is necessary for the deviation in the original specs.That's what I've been saying all along! I was referring to NTSC in it's original form, as in OTA or cable.
