can not locate g10r
dlhutch62
San Angelo, Texas
I have a fta-ptc pantec ultra receiver
wineguard ds2076 76cm
digital ku band single lnbf
rf:11.7~12.2GHz
if:950~1450MHz
L.O.:10.75GHz
NF.:0.3db
LAT:31.4, Long:-100.4
I can locate echostar9 121 & galaxy13 127 with no problem. I have a clear line of sight, no obstructions.
Is there an easy way to locate g10. It seems to me that the signal from 121 is overpowering 123. I have marked both 121 & 127 on the post, 123 has to be in between the two. I do not have a motor nor plan to get one. Any help will be appreciated. Thank you. dlhutch
since you can get a couple other satellites, you're close :)
I would use the below frequency to pick up G10…Its very strong
11805 frequency
H polarity
4580 symbol rate
Welcome to the SatelliteGuys.US FTA forum :welcome
If you think you are close to the satellite try a blind scan!
Let us know what channels you get and we can tell you what way you have to go..............
It's just a hair to the right and down from 121. Mirco movements and a linear lnb is all you need. Shouldn't be hard at all with correct setting in you box matching up with your lnb.
A No-Bee question.
Pansat 2700a - Timer....
