Channel master rotor problems
classic cartoon fan
SatelliteGuys Guru
123
Preble County, Ohio
Ever since this bitter cold weather hit us in Ohio (currently 13 degrees F) my antenna rotor has not been able to budge. I pressed the sync button and it still didn't do anything. I last used it on Wed the 30th with no problems, but today haven't been able to get it to do anything.
This a channel master rotor.
Any help would be appreciated.
You can try it. Worse that will happen is it doesn't work. This is one reason I use multiple antennas, after experiencing what you are now going thru, 3 winters ago. Now I don't have to wait for the antenna to move to get reception. Just change the channel and wham bam thankyou maam'. ;)
Is there anyway to check if the rotor is working without bringing it down? Mine is 200 ft up in a tree. I bought a new cm 9357 controller. But still doesn't turn. And I am not sure it is syncing right. It does not sync to the antennas position. The wires do not seem to be shorted out at this end anyway
Are you using the chincy round wire that Channel Master sells? My 9537 quit working & it ended up being the wire. Replaced the wire with more something more robust & all is well 5 years later. (Radio Shack flat wire)
No More TV Guide for OTA
Help with Picking out Antenna TV FOOL report included
