I believe Magic Chef is another Whirlpool name brand.
It actually owned by CNA dba MC Appliance Corporation...I believe Magic Chef is another Whirlpool name brand.
The production part can still be done by another 'name' or even a 'contract' builder. Just north of where I grew up is an appliance (freezers) manufacturing plant, owned by now-bankrupt W.C. Wood. They made products for a few different brands, including Haier. More recently, Whirlpool bought them and in that plant, they now produce Whirlpool, Maytag, and Amana branded freezers.It actually owned by CNA dba MC Appliance Corporation...
"...If you're in the market for a new carpet sweeper wouldn''t you like to know what brand and model does the best job and what that model sells for?..."
Considering their poor testing of vacuums, it just reduces their credibility. They downplayed the Dysons. In my previous job, we went thru MANY models of vacuums. Most lasted maybe six months. Then we got a Dyson. It lasted longer than the business did. And it never lost suction. Years later, beat up, scratched, gouged and with stains on it, it was still working fine. CR is a guide, and certainly not a definitive one.
Read what Hall said above.Direct does not use 1920x1080i. Did you read Scott's post comparing both side by side?
Hence the mystery. If you look up CNA, it doesn't seem to exist.It actually owned by CNA dba MC Appliance Corporation...
Yes, and while two products are from the same company and have the same specs, it is often the diffence is in the QUALITY of the PARTS, which can affect performance and almost always durability. There are cheap capacitors that will bulge in a heartbeat just sitting on the shelf and start to give you performanced problems before they eventually DIE, and more expensive capacitors that won't bulge or give you problems for as long as you use it.Since Sears sells both LG and Kenmore, it isn't difficult to identify many striking similarities. There are only a handful of companies out there that make appliances outside of the stupid money brands (Viking, Miele, Thermador, Sub-Zero and Liebherr).
Whirlpool is the company behind Amana, Jenn-Aire, Kitchen Aid and Maytag as well as four or five other brands.
Electrolux is behind Eureka, GE (appliances), Gibson, Kelvinator, Philco, Tappan, White-Westinghouse and a couple dozen other brands.
Bosch, Haier, LG and Samsung are the big brands that aren't in bed with Whirlpool or Electrolux.
Magic Chef is a mystery.
Just because the same parent company is behind them, it doesn't follow that they are all clones of each other. It is more like Chevrolet vs. Buick where one company will take the high road and the other not so much. I think it a safe bet that Sears demands more than LG does in terms of quality yet most all of the Kenmore branded equipment is built by LG.
It is important to note that while the DIRECTV picture quality was rated higher, both companies were given the same overall score (probably weighted heavily on ease of use) and both were rated as poor values. Whatever advantage DIRECTV has in picture quality, Consumer Reports believes they piss away somewhere else.
Perhaps the most damning fact behind the survey is that it is conducted using a sampling of Consumer Reports subscribers. This is contrary to what I said earlier. My bad.
In many cases, the products are literally 100% identical except for the branding though. Even using your example of capacitors and using cheaper ones, but you also have to look at it another way: The manufacturer can buy twice as many "better" capacitors and possibly get them for the same price (because of volume pricing) as the cheaper capacitors.Yes, and while two products are from the same company and have the same specs, it is often the diffence is in the QUALITY of the PARTS
I find that DIRECTV's gamma and chroma are considerably jacked but it does help whack the dark greys that cause problems for DISH. Not being a seared retina type, I dislike the DIRECTV profile.Maybe DirecTV doesn't need to compress as much of the data as Dish and that is why some consider their PQ better, or is it that DirecTV has made different choices of what to compress to have a subjectively more aesthetic apperance than Dish.
DIRECTV gets 6 channels per 32MHz transponder while DISH gets up to 8 channels per 24MHz transponder. The differences between Ku and Ka comprise most of that difference.
The numbers represent the bandwidth of the transponders. The frequencies of Ka are in the 18-20GHz range while Ku is in the lower 12Ghz range.Interesting comment. I thought 32MHz or 24MHz was a bandwidth. Shouldn't that tell us what they have to work with? Ku or Ka should be the center frequency, and not a bandwidth.
