Directv dish antenna not compatiable with any other brand receiver?
Rax
Apr 2, 2014
4
United States
Hello
One of my friend gave me a used directv antenna set(SWM 3 LNB slimline dish??) for free and I'm wondering if it works with non directv satellite receiver because I'm considering to get a FTA receiver in the market. but Some guy says I initially would have to figure out if there are any specific features in the receiver before get it.
Is it right? if yes, How do I find out a right stuff for it.
Really appreciate in advance.
Thanks!!
bobvick
4,471
2,169
Northwest Alabama
You would probably get better answers to your questions by posting this in the FTA forums.
To help you a little, in order to use a Slimline for FTA, you would have to rig up a way to get a linear LNBF on it, the Ka/Ku LNBF that DTV uses is circular and will not work on a satellite where you would find FTA. Check out lyngsat.com and global-cm.net, to find out what you might be able to get on Ku-Band.
FirstClass
Feb 13, 2014
18
4
USA
I routinely receive DVB-S HD and some DVB-S2 HD signals on 85° and 91° using an 18" round DTV dish. Swapped-out the feedhorn with a ku PLL-1KS and using a microHD receiver.
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
27,065
7,381
EM75xb
Welcome to the site Rax!!
Yes if you get a bracket or fashion one and buy a good ku band lnbf, it will work for a lot of stuff that is FTA. Some of the DVB-S2 stuff and others will be hard to get but it is still enough to get your feet wet.
Then get you a DVB-S2 capable receiver and you are good to go.
Ok FaT Air You make a lot of sense, KU-Band it is.
Thomson-Saginaw Ball Screw Reed?
