DIRECTV Transponder Map ~ Data 10/21/2026
It's only available for streaming customers, they still haven't added that batch of CW stations to satellite.
Even if it was, satellite customers still can't stream their CW affiliates via the app, just the Big 4, select PBS stations and some independents (mainly the ones that have full season NHL/NBA rights)
Reactions: dtv757 and Mr Tony
WCWW/25 CW South Bend and WBKP/5 CW Marquette are now testing on the stream server. These are both already available on satellite.
Now live in the satellite guide:
663-2 PISTONS (663-1 is likely being reserved for an overflow feed of Detroit Sportsnet, if there's a 2027 MLB season)
675 THUNDER
693 CLIPPERS
Reactions: Mr Tony
DirecTV Satellite Transponder Updates for Oct 21 2026
Comparison of Transponder Data for Oct 21 2026 vs Oct 14 2026:
No changes in system tables for any transponder tuning parameters.
Changes to the use of defined transponders:
1 Transponder cleared of all Streams::
Net 10 TID 126 Beam NAT is a National Transponder on D11@99cb, TPN 3
1 Previously unused Transponder with current APG records::
Net 15 TID 15 Beam NAT is a National Transponder on D12@103ca, TPN 16
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
264​
2​
1449​
SD mpeg4​
145​
194​
SD mpeg2​
433​
RB​
Audio​
89​
Push​
26​
Slate​
19​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4​
SD mpeg2​
RB​
Engr Work​
38​
-2​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
NBA Updates
Weekly Analysis soon
Enjoy
DataDigesters
HAWKS, HORNETS, GRZZLIES, HEAT, MAGIC, CAVLIERS, TWOLVES, BUCKS, PACERS and SPURS channels have also been added, however they are pointing to a TV Promise slate, which says they are working with DAZN and others to strike a deal for those teams.
Some more TPN swaps
Some more TPN swaps
Wait…..
So even though DAZN keeps touting 'only way to see games' if you are a subscriber to Choice (like my stepdad) if an agreement is reached he can see the Wolfies on 668?
I know the Wild are in dispute and a slate is on 668-1.
675 THUNDER
693 CLIPPERS
They're finally live in the app's API, doing a check
PISTONS is not available in Detroit (WMYD/20), it is available in the rest of Michigan including Marquette who also gets the games on their MyNet station WJMN/3, along with the Toledo DMA and the northern portions of the South Bend and Fort Wayne DMAs.
THUNDER is available in OKC and Tulsa, so I wonder if DTV is just going to keep the OTA feeds of KSBI/52 and KQCW/19 and direct viewers to 675 for the rest of the games.
On stream it's in Choice for Oklahoma (inlcuding the Oklahoma portions of the Amarillo, Sherman-Ada, Wichita Falls-Lawton and Joplin DMAs) and Western Arkansas and requires Sports Pack for Nebraska, Kansas and Western Missouri, I'm not sure if it's the same for satellite.
Reactions: Nate.O’Brien
Some more TPN swaps
It appears we are not getting both home & away feeds out of market on League Pass for these teams either…
I've been watching the Spurs home feed on channel 676-1 (was part time San Antonio specific feed) out of market with NBALP for YEARS on satellite (through the multiple iterations of Fox Sports SW, Bally Sports SW, FanDuel Sports SW) Looks like that will not happen unless a deal is reached with DAZN. I do see the placeholder channel on 680 if it happens.
Center Ice does have the non-carried feeds, including the Hurricanes, Wild, Blues and Blue Jackets and spotbeam local only teams like the Panthers, Mammoth and Golden Knights. So it probably depends on the available part time bandwidth each night as things they are able to provide to in market viewers in the 600s, PPV Events in the 100s and commercial events in the 9000s get priority first, along with games where neither team has a remappable feed.
Reactions: coolman302003
App channels disappearing and reappearing
