DIRT - 722k Freeze Issues
kcburk
90
Mississippi
I just relocated my rcvr to a new home this week. Since the move the rcvr has been freezing during shows, usually during commercials. Tonight was watching ESPN HD and had poor sound quality. The rcvr kept freezing during commercial breaks. Also, had DVR playing a reçording on tv2. It froze and wouldñt let us resume the show even after a hard reset. Do you think the problèm could be the hard drive or the cabling in the house?
Thanks.
With out knowing your signal strengths, the type of dish on your building or even being able to test the electrical feeding to your reciever, I wouldn't really be able to tell you for sure. But my past experience when people move their dvrs from one house to another they get jarred around and the hardrive becomes damaged.
I would suggest picking up an external harddrive and relocate your recordings before the reciever fails.....
Did you have a professional installation at the new location or did you just connect to an existing dish? A poor signal could cause poor video and audio.
That's a good point.
Did a Check Switch Test and saw 61% signal strength.
You have 2 or 3 satellites with up to 32 transponders on each so you have more than one signal strength of 61%. Try menu 6-1-1 and then move transponder and satellites to get different signal strengths.
211/211k - Can Either Connect to SD Set? Both Have Built-In OTA?
sling adapter ID dishnetwork help
