Greetings from a first-time poster. I was searching the archives and couldn't find a consensus as to whether a pole mounted in the ground should be filled with concrete. I am self-installing a Dish 1000.4 EA and will be mounting it on a 1 5/8" pole (standard 1 5/8" chain link fence pole from Lowes.) The pole is already plumb with 100 pounds of concrete around the base (in the hole that I dug in the ground). The part of the pole above ground is 5 1/2 feet long. The base seems nice and solid but the pole itself seems to be a bit springy (and the Dish isn't mounted on it yet.) Should I worry about this? I read that if I fill it with concrete, it may rust the pole out faster.
Thanks in advance for any advice on this.
Andrew
Andrew
