Dish 1000 signal loss on 129
fubar21
11
Newport OR
:confused: I have a 811 & Dish 1000 I'm waiting for my 622 install date march 11 I live in Newport OR 97365 and can only get 60-70 on most of the trans but my ? is I can watch the point dish. on sat 129 tans 30 I will have 67 which is fine but after about 45 min I will loose lock and go to setup and I have 43 on sat 129 tans 30 after about 7 min its back to 67 and is good for 30-45 min and back to 43 no lock and 7 min its OK. no wind or rain is it my dish 1000 or the 811. thanks for any help:confused:
How long have you had the Dish1000? It may still be under warranty if an installer put it in for you. If an installer did install it then I would contact them to come out to correct the problem if it is covered under warranty.
Also have you checked to see if it has done the same on 110 and 119 or does it only do this on 129? What kind of signal quality do you get on 110 and 119?
The locals from 129 were going CRAZY (weird - something similar to pixellation but something different) yesterday morning in the Charleston/Huntington WV market (or at least it was at my place). They are fine now. I checked the signal strength and it seemed normal and no fluctuation.
Thanks chrisjs atleast iam not the only one and now I konw its not my 811 hope thay fix it soon or more of us have the prob so thay will stop saying its just me.
chrisjs said:
This seems to be a problem here in the PNW see more posts on dbstalk at:
http://www.dbstalk.com/showthread.php?t=53368
I am not sure what to do with my 622 install tomorrow. I will probably go with 2 dish 500s.
Christopher
It's been discussed throughly on this forum also, with the OP contributing. here's the thread:
http://www.satelliteguys.us/showthread.php?t=56866
SO we know that the 1000 is a bust in the PNW. The question is what can we get Dish to do about it?
my question is will they be able to do anything about it ? If the issue is basic "physics", angles and the like, then can they do more ? :confused:
I was under the impression that d1000 was to address govt's mandate on all locals on the same dish.
Does this law/rule also state that the local signal quality has to be perfect ? if not they may decide to do nothing, they met the ruling :devil:
Maybe one of the legal eagles on here can help define if they will need to fix it.
The satellite at 129 has damaged solar panels and some other problems. I am surprised they are loading it as heavily as they are.
When Echo X comes into service it will be interesting to see what they do with the existing sats at 110.
I've noticed in wind, that 129 is the first to lose a lock. I would attempt to reaim the dish but dont expect anything over 80 for a signal strength.
but way does it work for 30-45min and loose 30points and come back after a few min and is good for 30-45min. you can almost time it like someone is fliking a switch.
No one responding in the PNW has received a signal higher than the 60's on 129 !!! We would all jump for joy if we could get in the 80's.
"I am surprised they are loading it as heavily as they are. "
I just don't understand why they keep adding channels to 129 when it's so weak. It's not only for the PNW but for the West coast in general, you can only get 60s and 70s in all TPs. You get a pretty bad storm with winds and you're SOL. I really hope they move one of the satellites at 110 like it's been suggested to solve this problem.
I putt 129 on my old dish 300 got the sig up to 75 butt still after 30-45 min it drops to 48 and i loos lock butt it comes back after 3-7min and is good for 30-45min.
It could be that you have a bad LNB or bad connectors. Check the connectors, you could also try a different cable. My signals are low compared to 119 and 110 for 129 but it locks and it doesn't drop like yours.
I do hope they put something newer and better to 129. Reminds me of when they used an old used satellite for 105 at first then they put a new one there later.
I have a clear line of sight no trees went to raodioshack got a new lnb same. so I'm going to wait till march 11 for my 622 install and see what happens i will let you know what i get. thanks for all the help.
New dish bill seems wrong
Cost of Dish?
