DISH 300 to DISH 500 question
J
John David
4
I have a DISH 300 installation at my lakeside home which I visit infrequently. I am able to carry my DISH receiver there from my regular home.
What hardware do I need to buy to convert the roof mounted antenna to a 500? Just the 500 dish or do I also need a new LNB ?
You're going to need a new LNB as well as the dish. The one that you have on the 300 is only able to look at one satellite.
OK, so I must get a new LNB for the DISH 500 dish. Will a DISH PRO LNB work with my 3 year old receiver?
John
DishPro supports Models 301, 501, 508, 721, 811 & 921. For your 500 set up, I would go with the legacy LNBF. There's one on Ebay that will probably go cheap. The fellow who is bidding only has won one item in the past so you probably can get it for a couple bucks with a snipe bid if no one else bids.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3088205132&category=32843
Good luck
The lnb by itself will not do the job. You will need the "y" attachment, and I am not certain you will be able to get a consistent signal with a dual lnb on a 300 dish. It is a couple inches shorter than the 500 dish. You might want to search ebay for a complete dish 500 with the lnb. I am not really familiar with the dishmover program but you might also check into it if the prices for the dish 500 and lnb are too high on ebay.
Another alternative is to get another 300 unit along with a sw-21 switch. The 300's with the lnb's are usually pretty cheap on ebay and the sw-21 have come down a lot in price.
Good luck!
yeah, just go to ebay and get one. I pretty sure they are cheap. I use to have several of them laying around. If I had one I'd send it to ya.
The other thought is to ignore 110 and live off 119 at the cottage. Unless you have locals there or a Spanish subscription all you will miss is PPV and AT180 non-AT120 channels (and a couple of movie channels).
Check to see if the Dish500 came with the Y you will need, and that all of the other parts are there. I'd hate to see you nickle and dime yourself over a couple of channels on 110.
JL
eBay success
Thanks for suggestions. Got a used DISH 500 with twin LNB for $26 on eBay.
Was able to pick up locally.
Similar threads
M
Replies
13
Views
1K
tjboston5676
tjboston5676
B
Replies
Views
842
tjboston5676
tjboston5676
R
Replies
14
Views
1K
rvvaquero
rvvaquero
D
Replies
6
Views
1K
That American Girl
That American Girl
B
Replies
12
Views
424
rvvaquero
rvvaquero
  • John David
