Dish 500 LNB connections
tpinck
SatelliteGuys Guru
139
35
I have the dish 500 dish with dual LNBs. The LNB head has 3 output connectors, labeled 1, 2 and ??(I forget). My installation only uses connector 1 hooked up to my DVR receiver. I typically use a Winguard Sat finder on this output and a 15VDC source to lock on and peek the dish and then connect the receiver.
My question, can I hook the sat finder with the 15VDC source to connector 2 and the receiver to connector 1 at the same time? Woud having the two seperate voltage sources damage the LNBs or the receiver?
Tim Pinckard
www.timandpegrv.com
Tim Pinckard
www.timandpegrv.com
Just for your information you don't have DUAL LNBs you have a TWIN in fact from your description you have aDish Pro Plus TWIN.
The Big Ten Network
Need opinion on DVR #625
