Dish DVR 625 3rd Receiver question
darkknight74
11
Texas
Hey guys,
Just got my new 625 installed to day said that he need to change the LNB so he changed it with a dish pro plus. The LNB had 3 coaxl nubs to attach RG6 he said that he was only going to be using one plug and that the other one I could run some RG6 and install my 501 as a 3rd reciver in another room. sorry if this is a simple question but can I do that he said that no switch was needed and that I had an extra port on the LNB to add another box... I thought you needed add a switch to add a 3rd receiver what is you guys advice.
My set up is a 625 dual tuner with 1 tv in the living and 1 in the bed room I can watch and record indenpdent of each other I looked for some kind of switch under the house eve but nothing.
the LNB is a dish pro plus
The 3rd connector on a DPP Twin is an input for a 3rd satellite source. You are correct about needing to add a switch for a 3rd receiver, however in your post I only see mention of 2 receivers.
So, with the DPP Twin, 1 RG6 is run to the dual-tuner 625 where a DPP Separator directs the signals to the 2 tuner inputs. Another RG6 is run to the 501.
DishPro Technology: http://ekb.dbstalk.com/217
DPP Twin: http://ekb.dbstalk.com/35#dpp
What’s receivers are considered "Legacy" ?
Help me install OTA antenna with Dish 1000
