DISH LNB or LNBF?
Zephyr Triple Crown
14
4
FL, NY, KY
I moved my H3 from the Coach to the Park Model and the signal is weak. On the Coach I had the Winegard Trav'ler. At the Park Model I got a fixed dish setup from Solid Signal. DISH Network Triple LNB HD Western Arc (VOOM) Dish Antenna(DISH1000.2). Just couldn't get it to pickup a signal. Took the LNB from the Coach and I got a signal that gave me service but the slightest foul weather it was out. Apparently the LNB from Solid Signal was a Reman piece. I complained and they refunded me. So now I'm thinking that my Coach LNB is getting weak and I should get a new one. From what I've read here that any that you get for DISH is Reman even if it says that it's new it's a Reman? How do I tell if my LNB is 100%? And what I'm buying is good too. Do the LNB's fail because of sun damage to the white horns on them? The two triple LNBs I see are the 145511 and the 151027 Hybrid? (I think I have this one). My system consists of the above dish and LNB, a DPH42 Switch and a power inserter and a splitter node then to the H3 receiver. Thoughts? Thanks
Get rid of the triple, the 42 switch, and the power inserter, and see if you can get a Dish 500 kit with a Western Arc Hybrid Twin LNBF. That is compatible with ALL receivers now and is what is used on all installations (Western Arc)
A couple of the things you asked didn't really get answered yet, so here's what I'd check before buying another LNB.
First, how to tell if an LNB is actually going bad: don't go by one signal number. Go into Point Dish and check signal strength on 119, 110 and 129, scrolling through a few transponders on each. A healthy LNB is fairly even across transponders on the same satellite; a dying one usually shows some transponders much lower than the rest, or readings that drift down as it warms up in the sun. Run the same check cold in the morning and again after it's been in the sun, and run Check Switch — if the switch test starts failing or losing a satellite intermittently, that's the LNB or the cabling, not the receiver.
On the 'new vs reman' question: a lot of the LNBs sold as new are in fact remanufactured — look for a reman sticker, a date code, or a feedhorn that looks scuffed or sun-faded rather than clean white. A reman isn't automatically bad, but I wouldn't pay new money for one without checking that, and I'd test it the way above rather than trusting the label.
And yes, the sun does kill them. The white feedhorn caps get brittle and crack after years in the sun, moisture gets in, and the LNB starts drifting or dropping out in rain first — which matches your 'slight foul weather loses signal' symptom. Look closely at the cap and the throat of the feedhorn for cracks or green corrosion, and check the coax connector at the LNB for water as well.
On your two triples: 151027 is the Hybrid triple, which is the one you want with a Hopper 3, and 145511 is the older DPP triple — that one is why you need the DPH42 and the power inserter in the chain. HipKat's suggestion to simplify to a Hybrid setup removes two failure points, and I'd agree with that if you're replacing parts anyway, but I'd do the signal checks first so you know whether it's the LNB, the switch, or just the feedhorn cap before you spend on anything.
Hopper 3 - Resetting and Rebooting using different methods and what each of them actually does
