Does any of the CBand satellites use circular lnb's?
wildboys
328
Does any of the CBand satellites use circular lnb's?Between sats 43 thru 55w
Yes they do. Check Lyngsat. any of the C birds that show L and R instead of H and V are circular birds. They are basically on the atlantic birds
I had a question speaking about circular LNBs.
If you have a Circular LNB set up is it possible to get signal on the Linear H V birds too? I been told that you can but not the other way around. Signal may be less on the HV birds but you can get them with a circular LNB that you would with an H V LNB.
I just wanted to verify if that was true or not.
there is a plate that goes down the LNB to make it circular so you might get V/H stuff but at a lower signal
I know for a fact that you can pick up circular birds with a linear LNBF at a lower power. This signal is cut about in half. It proves to be annoying when using a QPH-031 to scan linear birds where there is a circular bird at the same orbital slot, or, as in the case of 119w, a powerful circular bird adjacent to a linear one :)
attn: Mission Impossible fans
HTS Tracker System V Remote
