Dp-21 Switch And Vip622
chitown said:
I also have the current setup on one 811 and also have a 301 .
I just received my 622 and plan on swapping it out for the 811. I have 110 ,119, and 61.5 .How exactly would I be able to run another line off of the dp-21 ?
Also is it normal for the the switch to be installed on the roof of a two story house directly next to the dish ?
You're going to need another DP-21, and make sure the 61.5 LNB is a dual output.
in an earlier post i stated that my attempt at backfeeding the 21-69 was not working. well i have corrected it. 2 conditions now currently exist. some channel are taking maybe 8 seconds or more to load? is this a switch issue? also there is some snow on tv2. is this signal loss?
condition 1
i should be more concise. all connections are clean at diplexer's. there is approximately 50 feet of cable from the diplexer to the dish. i thought maybe the length could cause some loss of signal.
condition2
i am attempting to backfeed(21-69) to 4 tv's and modulate both tv1 and tv2 out. tv2 modulates fairly well with snow increasing as it comes to the last tv. tv1 modulates in black and white. i think there are 5 splitters in all and approx 120ft of cable. probably need some amplification.
one other thing are splitters bi-directional. as in "can one be used to combine an ota signal with the (21-69) output?
otherwise everything is perfect:)
WNYW (NYC FOX) HD Having audio dropouts?
Already crashed my 622 more times than I can count
