I need my primary output (TV1) to be operated in both IR and UHF mode. In the manual for the DVR 625 it shows that you can change the PRIMARY REMOTE ADDRESS to show UHF PRO AND IR. (It's right in the graphic on the "Enabling UHF Pro" page of the manual. However, I can only get it to *either* show UHF Pro or IR next to the little green TV1 icon on the System Info page. I can't get it to show the UHF AND IR label as it shows in the manual.
My 722 does this just fine, and my 501 did it just fine. And the manual for the 625 shows I can but I can't make it happen. Please help me figure this out.
Reason. I use this "little used" input to feed two things. My TV in the basement which I use the UHF transmitter to reach the 625 in my wire closet. While traveling, I also have a SLINGBOX sharing the output. The SB is only IR so I need TV1 to be able to accept IR for when I use the slingbox and UHF when I'm home in the basement. Again, I had the same setup on my 501 and it worked, and my 722 upstairs also works fine (I have another Slingbox there as well).
