FIOS deleting channels question
tvwatchingdude
164
I am getting FIOS installed next week. i dont plan on subscribing to the movie channels or any foreign channels. Is there a way i can delete these channels so when im channel surfing i dont have to see screen after screen that says "ORDER THIS CHANNEL" like i had to do with cablevision. Its so frustrating. I know that these channels exist and NO THANK YOU! I DONT WANT THEM. your help would be greatly appreciated!
Just order the channels and the message will go away.
Expensive HDTV... check
Expensive livingroom furniture... check
Expensive surround sound audio system..... check
Premium channels.... NOPE, wtf?
Why have all that nice stuff and then stick with basic cable? Do it right or go outside and play!
Yes, you can do that, in a way. Set up a favorites list that has the channels that you get. Then you can set you favorite list to be active. When you do that, then only the channels in that favorite list show up in the guide, and they will be the only ones that you hit when channel surfing. Also, the active list stays as the active list until you actually change it. Even after you shut off the set top box, and turn it back on, the last list you activated will be the one your box will be set to.
I only have one nit with the functionality going this way. When you activate the list, your guide will no longer scroll around from end back to the beginning. Once you hit the bottom of the guide, you can't just scroll back around to the top of the guide. You have to go backwards.
Trouble with compression fittings for RG6 quad
fios pre-installation
