Forum Guide: How to Fix Stuck "Download ATV Files" Loops under Diagnostics > Receiver > Tools > TECHNICIAN SETTINGS
Almighty1
1,824
1,857
San Francisco, California USA
Troubleshooting Indicator: If you Download ATV Files under Diagnostics > Receiver > Tools > TECHNICIAN SETTINGS and find that after waiting an hour or more, the selected file components do not all complete successfully and remain stuck in an incomplete or failed state, you will need to perform the isolation sequence outlined below to clear out the broken cache.
Why the "Download ATV Files" Loop Gets Stuck
When you trigger Download ATV Files under Diagnostics > Receiver > Tools > TECHNICIAN SETTINGS, the system treats it as a critical update deployment rather than a standard app download. If a few file segments fail to download or verify due to a local network hiccup, the system gets trapped in an unresolved "In Progress" limbo state.
A standard red button reset or letting the nightly system updates run will not clear it for two main reasons:
  1. NVRAM State Preservation: The Hopper 3 runs a customized Linux OS that writes active update installation flags directly to its NVRAM (Non-Volatile RAM). This safety feature prevents the receiver from getting "bricked" during an unexpected power outage. A standard soft reboot instructs the system to protect these logs, causing the bootloader to read the unfulfilled update tag on startup and immediately reload the stuck loop.
  2. The Hopper Plus Memory Handshake: The Hopper Plus is an independent Android TV computer with its own power supply. If you reboot the Hopper 3 but leave the Hopper Plus plugged into the wall, the Hopper Plus never resets. The millisecond the Hopper 3 wakes back up, the Hopper Plus re-establishes its hardware handshake and signals the receiver: "I am still awake, and I am still missing files." This immediate hardware trigger forces the Hopper 3 to instantly reload the "In Progress" flag back into active memory.
To clear it, you must create a temporary environmental vacuum that forces the Linux kernel to break its own safety protocols and abort the task.
__________________________________________________
Step-by-Step Isolation & Reset Instructions
Step 1: Kill the Internet Connection (Mandatory)
You must completely block the receiver from reaching the internet so it cannot instantly re-authenticate and fetch the broken file headers on boot.
  • If using Ethernet (with or without Wi-Fi backup): Physically unplug the Ethernet cable from the back of the Hopper 3 receiver. If you have ever used Wi-Fi in the past, you must also execute the Wi-Fi removal steps below so it does not fallback to wireless.
  • If using Wi-Fi Only: Clear out your saved network credentials using this specific remote sequence:
    1. Open the Diagnostics menu.
    2. Select Internet → Internet Settings.
    3. Press Info, then press Recall.
    4. Select Yes on the Clear Wireless Settings prompt.
Step 2: Execute the Hardware Reset
Path A: For a Standalone Hopper 3 (No Hopper Plus Attached)
Because a standalone unit handles everything inside its core satellite registers, it requires a complete electrical power drain to wipe the background cache. Using the front-panel power hold allows you to execute a true cold boot without unplugging cables from the wall.
  1. Disconnect the internet using the steps in Step 1.
  2. Open the front-right door panel on your Hopper 3 receiver to reveal the physical buttons.
  3. Press and hold down the large, square physical Power button (located on the far left of the row) for 20 to 30 full seconds. Note: The solid green power light will turn off immediately—keep holding firmly through an intentional out-loud countdown to completely discharge the board memory.
  4. Release the button.
Path B: For a Hopper 3 with a Hopper Plus Module
The presence of the Hopper Plus allows you to use a front-panel hardware override to clear the loop without reaching behind a heavy equipment stack to pull the Hopper 3's power cord, provided the external module is simultaneously isolated.
  2. Unplug the physical Hopper Plus power adapter directly from the wall outlet (this drops its independent data cache).
  3. Open the front-right door panel on your Hopper 3 receiver to reveal the physical buttons.
  4. Press and hold down the large, square physical Power button (located on the far left of the row) for 20 to 30 full seconds. Note: The solid green power light will turn off immediately—keep holding firmly through an intentional out-loud countdown.
  5. Release the button.
Step 3: The 30-Minute Timeout Buffer
Leave the system completely alone and undisturbed for 30 minutes.
When the Hopper 3 boots up completely offline with no network and no companion hardware attached, the update manager tries to read the pending download script and hits a hard boundary error wall. It will enter an internal background retry loop. Allowing it to sit for 30 minutes ensures that this background network clock completely expires, forcing the Linux kernel to finally abort the task, wipe the temporary memory stack, and flush the stuck "In Progress" text block under Diagnostics > Receiver > Tools > TECHNICIAN SETTINGS > Download ATV Files back to its clean default state. This window also ensures the system has ample time to safely detect and remount any connected external hard drives (EHDs).
Step 4: Reconnecting the Environment
After the 30-minute window has passed, the background tile will be completely flushed. Follow the specific path that matches your connection type:
  • For All Wired/Ethernet Setups (Standalone or with Hopper Plus):
    Plug your physical Ethernet cable directly back into the port on the Hopper hardware. The connection will initialize automatically. If you have a Hopper Plus module, you can now plug its power adapter back into the wall outlet as well.
  • For a Standalone Hopper 3 on Wi-Fi:
    Navigate back to your network settings and run the Wi-Fi setup again to enter your wireless credentials and connect the base receiver to your home network.
  • For a Hopper 3 with a Hopper Plus on Wi-Fi:
    1. First, plug the Hopper Plus power adapter back into the wall outlet and wait a moment for the status light to turn solid white and restore your video display link.
    2. Second, once the Hopper Plus is powered up, use your remote to access the network menus and perform the wireless Wi-Fi setup to re-authenticate with your home router.
PRO-TIP FOR HOPPER PLUS USERS: Once your internet connection is fully restored and you navigate back into Diagnostics > Receiver > Tools > TECHNICIAN SETTINGS > Download ATV Files, do not start a full download right away. Instead, isolate and download just the specific Hopper Plus files first. Letting those fully complete before running a full broad download will drastically lower the risk of hitting another partial packet validation failure.
  • Love
Reactions: HipKat
  • If using Wi-Fi Only:Clear out your saved network credentials using this specific remote sequence:
Step 2, path b - put the hdmi cable back in the Hopper
To clarify, the HDMI cable was never disconnected in this process—only the physical power supply adapter was pulled from the wall outlet.
Disconnecting or messing with the HDMI cable is entirely unnecessary for this fix because it only carries a one-way digital audio/video display signal to the television. It plays absolutely no role in the data sync pipeline, network drivers, or update validation scripts between the two boxes.
Before testing and confirming this method, I was specifically researching how to accomplish this hardware reset without disconnecting the proprietary USB link from the back of the Hopper Plus. Pulling the power adapter straight from the wall outlet was the cleanest way to do that. However, since cutting power to the Hopper Plus leaves you with absolutely no video to look at during the downtime, I had to engineer a way to execute the entire process completely blindly.
That is the exact reason Step 3 requires a 30-minute timeout buffer. Because you cannot visually see anything on the TV to track the system's progress, the 30 minutes acts as a blind safety window. It gives the isolated Hopper 3 more than enough time to complete its initial boot cycle, automatically detect and mount your external hard drives, run through its background network search routines, hit its terminal retry limits, and drop the stuck "In Progress" flag entirely in the dark.
Leaving the cables completely plugged into their ports provides the added benefit of less wear and tear on both the HDMI and USB connectors on the Hopper Plus, the receiver, and the cables themselves. Constantly unplugging and reseating rigid digital cables can easily loosen, pit, or strip the internal pin layouts over time. Unplugging the power adapter from the wall outlet handles 100% of the hardware isolation required to drain the cache safely and blindly.
Dish 4K Event Listings (No Discussion)
