fta questions
Techfizzle
Banned
985
the only dish i have used is a 10 foot winegard i scraped (couldnt get it to work right) and an old primestar that has cracked
I want a shiny new dish
1. What brand of dish is good?
2. What size of dish do I need to get decent fta reception I live in the midwest so im in center of most satellite footprints.. I dont want one over 3 feet
3. Whats a cheap motor that has usals?
1. winegard
2. 30-36" would be fine
3. its not the motor that controls USALS, its the receiver that has to support it
not bad. I have a Geosat dish which is the same thing and it works really good. 36" dish that I use to have on G10 until I upgraded to a 40x30 primestat
This is what I bought was it a good buy for $75 shipped? Will a cheap s2100 work okay?
You are viewing on an auction for
One brand new
33"Offset Universal dish
with one single lnb DGL-780 LNB
75 cm Dish Antenna
  • <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; COLOR: teal; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list .5in">Offset antenna with rolled-in edge to against deformation. <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; COLOR: teal; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list .5in">Rigid and Strong mounting design and easy assembly. <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; COLOR: teal; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list .5in">There are various stands for your installation at wall, ground, roof,
    railing, balustrade or slope. <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; COLOR: teal; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list .5in">Dish material: Steel <LI class=MsoNormal style="MARGIN: 0in 0in 0pt; COLOR: teal; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list .5in">Finish of reflector: Polyester Powder Coating
  • 40mm of LNB clamp is included. Any special size of LNB clamp is
    available to design for you.
Antenna Size:
75 CM
Reflector Optics:
Offset
Offset Angle:
27.8
Aperture Efficiency ±3:
80%
Horizontal Axis:
75 cm
Vertical Axis:
85 cm
GAIN@12.5 GHz Ku-Band:
38.9 dBi
Focal Length:
37.5 cm
F/D Ratio:
0.5
Mount Type:
Az / El
Azimuth Alignment:
360°
Elevation Alignment:
15°~ 87°
Pole Diameter:
30~48 mm
Operating Temp.:
-40? ~ +60?
Operating Wind:
90 km/H
Survival Wind:
180 km/H
BUMP
well?? sorry about bumping this thread but im am getting sleepy
EDIT: some googling confirms this is a AZURE SHINE dish I kind of like the idea that they have with the rolled in edege
some dishes are taller than wider so they take that into consideration
The dish I use for my Starchoice system is a 75e which makes it sound like a 30" dish but its 37 wide x 27 high
works the same as a 30" dish
is there anything that my dish cant get on digital ku?
well it depends on your definition of "can't get"
things you "can't get" (ie: cant see) on KU
-scrambled channels (DUH! ;)
-DC II channels (need a 4DTV receiver)
-satellites that dont beam to the US
-satellites that you may have a line of site issue
-satellites that may be below your horizon
in all seriousness unless a channel is putting out very low power that dish will be fine.
im talking about channels that may not have enough quailty to watch due to a smaller dish
Also i have a DCII receiver the GI one that was used for hits2home what can i get with it???
honestly those are few and far between...the ones we cant get are when the stations send enough signal for a 20 foot dish to pick up a decent signal but for us nothing :D
the 410? do a search on that. Most of us havent been able to get it to map to C-Band (W5 where H2H went to) but you can download Starchoice software/maps and get a few preview channels...check the C-Band area about it
any ku digital in the clear besides starchoice?
how do you edit maps i cant figure it out
nothing else that the 410 would pick up
as to how to edit maps, check the C-band area and search for 410..lots of info there on how to remap the box
Can You?
Hello Guys Need Some help getting started
