Green Dot on WJ4?
KAB
22,824
7,161
Fishers, IN
Wireless Joey 4. Yesterday, I noticed a little green dot on a small black field in the upper right hand corner of the screen, regardless of channel, recordings, etc. A restart got rid of it, but I am curious as to what It meant and what I did to get it there.
Google Search
The little green dot inside a small black field in the upper right-hand corner of your screen is an Android privacy indicator confirming that the voice remote's microphone is actively listening. Because the Joey 4 runs on an Android
The green dot on Android TV is supposed to show as long as an app or background service is actively using the microphone or camera. [1, 2]
What Normal Behavior Looks Like
    • When active: It appears (often with a small microphone or camera icon that fades into a simple green dot) the moment a voice search, assistant command, or streaming app requests audio input.
    • When it disappears: It should vanish a few seconds after you finish your command or after the app stops using the microphone. [1]
Why It Might Stay On (Persistent Dot)
If the green dot stays on indefinitely or won't go away, it usually means:
    • An app (such as a voice search tool, media player, or background utility) has a hung process or is keeping the microphone channel open.
    • A remote control or voice-recognition service is stuck. [1]
How to Fix or Check It
    • Restart your TV: Unplug the power cable for about 30 seconds and plug it back in to clear out stuck background apps.
    • Check app permissions: Go to your TV's Settings > Privacy or Device Preferences > Microphone to see which apps have access, and revoke permission for any suspicious or unnecessary apps. [1, 2]
Dish 4K Event Listings (No Discussion)
Dish Bankruptcy - Business as Usual
