HD upgrade wiring changes?
RWB
41
I plan to upgrade to HD soon. I know a new dish is required, but is the existing coax reused?
Routing was a major pain and I don't want the installer in my house longer than necessary.
As long as your wiring is RG-6 you should be fine.
It also depends on how many receivers you will have. If you're swapping, then no change is needed. Adding a second will require one extra cable from the LNBs to the receiver...
Aug 15th HD Upgrade
"Press GUIDE for Fav1" Message
