Help ! I have dish service . I am using dish outdoors , Wally reciever , dish HD disc, twin hybrid eastern arc . I am connecting to both sats , 61.5 &
teddrod
5
4
38115
I have Dish service, I am using dish outdoors mobile wally reciever, with dish HD disc, twin hybrid eastern arc, 1000,2 LNB, I can get both sats, 61.5 & 72, & both show locked signal. I don't get all my subscribed channels . Dish tech says I am not keeping sat 72 locked. Can any one tell me which port or ports I need to use on the LNB & DO I need any more equipment or cables added. I am using 1line direct from LNB port to reciever. Is my equipment satisfactory ? All setup & installation instructions are very vague
Pictures of your current setup would be nice, include your dish, lnbs and switches.
Which channels are missing? Are you traveling and out of the local spotbeam?
Would be useful to know which channels are missing so we can have an idea of which sat and transponder they're on... are they showing up in the guide at all? if so which on screen message do you get when you try to switch to them?
I am stationary . I am missing my extra dish movie channels & on demand channels 318 & above not all are missing
Is your guide set to All Subscribed? Do you have internet set up? Are you subscribed to Showtime?
Recheck your skew setting. That could account for the intermittent lock on 72 that Dish is seeing. If you move the skew, you may need to re-tweek 61.5 also.
It occurs to me, since I've seen it several times now, you may not be aligning the skew setting correctly. Please don't take offense if you already know this, since I have no way of knowing your level of expertise. The drawing below shows how the skew setting should be centered on the bolt on your 1000.2 dish.
Also as I said both sats are showing locked . But I run the status check & it only shows sat 61.5 . Why is this ?
They are both showing about 40% on the bar graph what is a tech roll . & what is the process
You mentioned earlier that the Dish tech said you weren't keeping sat 72 locked. Go back to that same number that you called and go through the process again and request that a technician come to your home and align your dish properly.
Dish Survey on New Guide
