So this is the station's response... looks like I need to reach out to tech support...
Ray –
You are partially correct. The TSID for WTTK is different than the TSID for WTTV, as required by the FCC. Because the TSID's are assigned by the FCC, I cannot legally change them.
Over the air, WTTK does transmit guide data which, in fact, is different than WTTV because 29.3 carries Cozi TV and 4.3 carries Comet TV. For 29.1 and 4.1, the guide data is the same.
The problem you are observing is that the Hopper box gets its guide data from Dish Network, not over the air as intended by the framers of ATSC. So, in order to get the Hopper to have guide data for WTTK, Dish would have to be persuaded to carry separate guide data for WTTK.
As an experiment, you can verify this by connecting your antenna directly to your TV and tuning to WTTK 29.1. You will find that WTTK actually does have guide data.
Thanks for your inquiry. Hope this helps. Feel free to reply if you have further questions.
