I am now on my 4th Hopper since October 2022. Why> Because no technician wants to really do diagnostics for the issue and the simple result of each call is to reset the Hopper. The last tech was a local one who like the others defaulted to replacing the Hopper with a NON remanufactured one like all the others were. Here's the problem:
Randomly, now 15 times since 12/23/2022, during active use of the Dish while watching a live program OR watching a DVR recording, the Hopper turns off and a Screen Saver displays. If left alone at that point the TV Guide will begin to download! My POWER settings are 8 hours for inactivity and don't do anything until 3am. The resolution is simply pressing the SAT buttone on the remote turn the Hopper back on. Result is back to Live mode, or in the case where a DVR was being watched jump to the end.
I'vebeen strung along through a minimum of 15 different technicians who only follow their script to look up symptoms they hear and then possible solutions to return to normalcy. Not one had a way to actuallt diagnose WHY the power kept shutting off.
Since this problem happens across all Hoppers installed, software, all Hoppers, or house power is of question. I have replaced surge protectors to remove that from the equation. Not a surge protector. I have presently gotten through day 2 of plugging the surge protector into the secon wall socket in the receptacle. We'll see if that help. Next I supppse I have to check wall voltage and fluctuations.
But first, is anybody exle experiencing this problem? The last of 3 supervisiors, after 15 technician and 2 other supervisors, tells me it is a know software prblem. What am I to believe since none of the others did except for me mentioning a possibility on the 12/23/2022 calls. After getting blown out by all the others with just try Reset or Partial Reset, I knew day 1 this corrected the OFF situation. But, inreality the answer should have been a simple hit the SAT button which did the same thing.
I'm looking for others who experienced this problem to come forward.
I'm also look for guidance on how I can diagnose the actual cause. I read about voltage fluctuations and low voltage and checking receptacles and can work on these. One question I have is that ONLY the Hopper on the same surge protectory, even when plugged into different sockets has the issue. The TV (Samsung) and other electronic equipment (far from too much) remains constantly up.
Since October 2022 I reported 12 DIFFERENT DVR issues or OTA Adapter issues. I have already learned NOT to use Prime Video Application on the Hopper because it conflicts with the OTA and DVR. After stopping this problems were reduced about 80%. Probably memory corruption between the different components. The OTA itself seems suspect at time because the "Guide ot Trobleshoot" message came up periodically and double DVR recordings on OTA channel occurred with first one less that a minute (the start early minute) followed by the recording of the show. This I assume happened becaue when recording started IT got the "Guide or Troubleshoot" message and simply ended the recording, but did avtivate the channel connection in time for the second recording to continue. Many issues like this suggest hardware conflicts and software mismanagement.
I'd be interested in discussing any or all the issues I am seeing since NONE of them have been diagnosed to a root cause. Dish simply isn't interested in that! Thank you.
btw. I read some devices are too sensitive to voltage fluctuations. Could it be all Hoppers are? And, that is why a Hopper will shut off and other things dont? Where do I find technical specs to address this question?
