How do I scan and keep stations located in different directions?
Ricknau
SatelliteGuys Guru
125
Just got an H-10. I receive OTA signals from stations located 180 degrees apart. I scan in one direction and log in all those stations. When I turn the antenna and scan again I get the new stations but loose the ones I already had from the first scan. How do you make the receiver retain the stations from previous scans?
Hmmm... 20 reads and no suggestions. I get the feeling this is going to be another "feature" of the H-10? :rolleyes:
After the original scan, after you move your antenna do not re-scan you must manually add the channels to your list. You can use www.antennaweb.org to get a list of channels in your area, this gives you a list of the channel numbers to enter manually.
DirecTV TiVo "standby" mode
My intsall is tomorrow, I have a questions
