Hr20 Hddvr How To Record
zakary95
21
it says in the manual that u can record three shows at once or record 2 and watch 1 or any combo if record one show at 7 pm and try to record another at 7 pm it won't let me need help the directions are not good at all
Your HR20 , if setup right, has two coax inputs from the dish. You can only record two programs at one time. You can watch a program that has been recorded earlyer at the same time or watch one that is being recorded at that time.
You better check the manual and read it again.
This was a misprint in the manual - you can only record a max of 2 things at once, whether they are on the OTA tuner(s) or from the dish.
You CAN, however, still watch a pre-recorded prog while you are recording 2 live shows.
Correct, and yes it was a misprint.
Jimbo
Well, on my new HR unit and 5 lnb dish, I can only record one show at a time. On a system check I get a "failure" reort on "tuner 2 - sat99b. I suppose that is the reason? Can I do a fix here or must I return the unit?
Jimbo
I guess I fell victim to that one as well, but it never really bothered me. I too understood that it said you can record three programs at once, or record two at once and watch another live. I found out that that's not the case when I was recording "24" and "Heroes" at the same time and wanted to watch a hockey game in the meantime.
I've had several flavors of this. Try swapping the cables to see if the 2nd tuner is actually telling you it's not getting signal, or if it's indeed bad. I had one LNB go on my old AT9, and a bad tuner on my 2nd HR20. Also, try a reset, on the off chance it's just the HR20 being flaky.
Thanx Hancox. It appears flakiness has reared its ugly head. Second time I tried the "unplug" routine, it worked. Someone elsewhere also suggested the "prioritylist" can be a source for such problems.
DirecTV to Light 8 Add'l HD Markets in April
YES-HD in FULL starting April 1st...
