HR24 / H24 CE Release 6/11
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,055
459
Central Michigan
Systems in this CE
HR24-500 • H24-100
Window of opportunity to download:
Friday, June 11, 2010 11:00PM - 2:30AM ET
Saturday, June 12, 2010 11:00PM - 2:30AM ET
Risk Level for this Download: High Risk
New features
Smart Search now gives Top Matches
Improved/Updated
Nothing of particular note
Notes
For all Hx24 MRV testing, please use SWM/MoCA.
If the box goes into standby during software download, please take the box out of standby using remote power button and complete the download. Report any download issues.
Please send logs along with all reports, including MRV issues.
When reporting issues, if feasible please send the log while the box is in the problematic state. In addition, please provide context around when the log was sent.
If feasible, when reporting issues, please indicate if these issues are seen on HR2x/H2x.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
If you revert from CE back to National x3E0, you will lose the guide cache, recordings made after CE, recordings played back since CE, Series Manager entries and the To Do list.
Channel logos will be unavailable for the first hour after download and require IAMANEDGECUTTER to be enabled.
This CE may remove your guide cache. Please allow up to 24 hrs to restore your full 14 day guide.
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:04:01(0x03E8) [HR24 only]
Posters everywhere!
DirecTV Cinema enhancements.
MOCA is the name of the technology for running ethernet over coaxial cable that was defined by the Multimedia Over Coax Alliance. Directv uses a modified moca setup called DECA. As far as I can tell the only difference between a plain MOCA setup and the DECA one is the frequencies that DECA uses on the wire.
MoCA :: Multimedia over Coax Alliance
CE's for the Weekend of June 11th
HR20 thru HR23 CE Release 6/14
