iPod battery question?
John Corn
The Coach / Supporter
1,237
19
North Canton, Ohio.
Looks like my sons battery is getting weak on his 4th generation ipod.
Anything I need to know about buying a battery and changing?
Where is a good place to buy the battery from?
Looks like the battery is user changeable, I was just curious if any of you have done it before and if it's tricky?
Most places send you the tool to open it with.
It's quite simple. I opened my 3gen iPod quite easily. It's the same as the 4th gen.
You can take something liek a .73 mm guitar pick or a SMALL screw driver
Then, you put it down on the right side, around 1/4 from the bottom. You'll know when you hit the right spot, it'll pop it out a little. THen once you get the metal part open enough, open the top plastic part, and the rest is easy. Take off the hard drive (carefully) then take the battery out. QUite simple. If you need any pics, or more explaination email me or pm me.
Zach
I replaced the battery on my Ipod Mini. The UON battery came complete with tools to make the replacement. The one caveat I would make is to be very careful with two things: 1) be careful when sliding the unit out of the case so you don't scretch the plastic screen; and 2) make sure all of the sliding buttons line up properly. Good luck!
Samsung to make a Digial SLR Camera
Garmin nüvi 350 GPS
