Is one of my 722k's about to fail?
Frank Jr.
Beati pacifici 5:9
13,798
1,908
Columbia S.C.
This morning around 9:30 my wife turns on the tv in the den and receives no picture/signal from the 722k. Other video sources worked fine. Audio from the 722k to my stereo receiver was ok. All front panel lights on the receiver were normal. I did a front panel reset with negative results. I then changed out the HDMI cable and ran to a different port on the tv with no results. Only after I did a power reboot did I regain signal to the tv. I left everything on for about two hours and everything seemed normal. I then turned everything off. I turned everything back on about an hour ago and everything seems to be ok.
I agree..Mine did something similar. Did a hard reset and it seems to be fine.. I think the last update was a big one.. My 922 did a few things also..
Just wanted to check and make sure everything is still acting normally. If it does happen again, let us know. We can submit a trouble report to our equipment department to assist you with this problem.
I have the same problem. I don't need to reboot the box to solve it, though. (Using the remote) I switch TV Inputs, and then switch back to the input where the 722k is located....does the trick everytime.
Comcast DVR vs. Dish DVR (functional differences)
Is Dish Platinum Online Not Available on the Vip 612?
