LEGIT firmware upgrade
$905.00
Unckle_Fun_Knuckles
84
Hey guys, can someone talk me through what is involved with a legit firmware upgrade for the foretec ultra? Is it complicated or what?
I havent downloaded a fortec, but Ive worked with about 5 or 6 others.
Its pretty easy
-hook computer to receiver with a RS232 cable (some need null mdoem cable...the manual/manufacturer will know)
-there ususally is a program that you open up and pick the sofware that you have
-hit OK and it downloads to receiver
It takes like less than a minute in a lot of cases :)
Thanks Todd for the info!
My Pansat & Coolsat use straight through but the KUSat uses null modem
Make sure when you look at the 2 diff firmwares to get the NTSC version. It says its for WinXP but it works fine with Win2k.
Perform a Factory Setting (restore defaults) before and after downloading software to your receiver.
EDIT MIDNIGHT - In fact I still have the latest FACTORY updater and flash file right here for you.
The fortecs are straight thru.. as far as I know, it only needs pins 2, 3, and 5 connected (TX, RX, and Ground) but as long as at least those three wires are straight 2 to 2, 3 to 3, and 5 to 5, it should connect.
Big Brother 6
Fortec Lifetime Ultra Satellite List Error
