LNB Output Failure H20-100 (with Zinwell WB68)
krmatth
16
Centerville, OH
Installed a Zinwell WB68 to add a 5t receiver. Noticed two things that have me puzzled. First, on my H20-100, the system test states "LNB Output Failure" but I seem to be receiving everything I'm subscribed to. Second relates to the Slimline dish. When I called to upgrade my system for the "new" HD I guess I expected to have 5 LNB's. When I access the receiver setup page the system asks which type of dish I have and defaults to the "3 LNB Oval" selection. I'm in the Dayton, OH (45458) DMA if that's any help. Is this normal and, if not, should I run setup again and select the 5 LNB option? Are my two concerns related? Note, I did not run setup again after installing the Zinwell as everything appeared to work correctly. Any advice is appreciated. (I've also posted this to the DirecTV Forums lookin gor an answer)
Hi... I have the same "switch" and a slimline so i'll check and get back to you. First a question - do you have four input lines to the Zinwell? I have four in and six out. :cool:
H20-600
Mine is a -600 but it reads Oval, 5LNBs and does NOT say anything about LNB failures ( this is all on the Info&test -- System Info) When I run the System Test, under LNB Output just says "OK"
Hope this helps.:cool:
Thanks for the info. I have 4 in and 5 out. Everything appears to be working fine so I'll just learn to live with the indication on the system test.
Is one or both of the OTA Tuner inputs on the HR 20 powered?
Direct TV in Mexico?
