Locals
rthornii
Aug 7, 2012
5
WV
I live in WV but recieve Pittsburgh local channels, I want to get Clarksburg WV locals...so I "moved" but I am still recieving the Pittsburgh locals.....any ideas or help?
well the obvious question....is the address actually in the Clarksburg DMA?
Clarksburg locals are on 129W...Does your dish face SW or SE? If SE then you have the wrong dish setup
Also FYI Clarksburg locals are SD only
2 ways to check
-go outside and look. The Western Arc dish (which you need) will be facing SW to W. Eastern Arc (which is used in some areas in Eastern time zone) faces SE
-on the receiver hit the "system info" button. It should show what satellites you are receiving. If it says 110,119,129 then you're all set. If it says 61.5, 72, 77 then it wont work
Ok I know I'm recieving 129, so that should be good...the address I used is in Marion County...so according to your map that should be good
I just ran a zip in that county and yeah it shows Clarksburg locals
might have ot give dish a call to verify they changed it
Yeah, they might have inadvertently changed the billing address instead.
then you might have to call (or chat) Dish and tell them that you are not getting the right locals. They need to send a rehit
Also make sure the guide is set to ALL to show the new locals right away
Welcome Pak does it inlude HD locals.
Won't Sling soon be a thing of the past?
