Low signal strength on 129
commodore_dude
220
Alpharetta, GA
Greetings,
I didn't realize this when I had my installation a few days ago, but the signal strength I'm getting on 129 fluctuates between only 40 and 50%. The signal meter on screen still colors this as green, but I'm just curious if that is an OK strength. I haven't noticed any issues yet when it's rained, but it's just odd to me that it's so much lower than 110 and 119, where I'm getting between 70 and 90% strength. I assume I have a Dish 1000 of some sort, although nothing on the Dish says for sure, the dish says "Turbo HD". Do I need to call Dish and get someone out here to repoint since I have a few months of their protection plan for free? Should I try for this Eastern Arc business I keep hearing about? When I had DirecTV at my apartment even with an 80-90% strength I was losing the HD channels in light rain, so I am a bit concerned...
Voyager6
*Cancelled*
17,097
5,324
Wokeville
Check out this thread and compare your readings to others. Depending on the TP, a reading of 40 to 50 is quite satisfactory.
iwannarock1
443
11
Stern nation
You need to give us more information. Transponder number can vary greatly on the 129. What is the strength on transponder 32?
I have a question for you also, if it's not giving you problems, why would you call in? You'll just get a technician a trouble call, or a subcontractor a chargeback, when you're not even having a problem....:mad:
commodore_dude
220
Alpharetta, GA
Thanks, doesn't look like mine are that much different from some of those reported. I'm getting 52% on tp 32. So as long as I don't lose signal outside of a severe storm, I guess that's ok, but if somebody gets a chargeback because this isn't good enough signal to ride out a light shower, tough noogies.
FitzAusTex
1,127
Austin, TX
Anyone have an opinion on why signal strength on Ciel2 at 129 is lower than E11 at 110? I know Ciel2 is an improvement over E5, but in general, on Ciel2 I get around 62 on most 17-32 TPs (21 and 32 are higher). I generally get in the mid 80s on E11 at 110. Just curious why the plan wouldnt be to achieve 80s for Ciel2. Perhaps E* is going to increase the strength on Ciel2 after they finish channel placement on all the TPs? I have a general recollection that E11 at 110 TP signal strength increased after being online for a few weeks.
Colorado springs hd locals
Does This Sound Right?
