mast question - want to relocate my DTV dish
johnm356
34
KA/KU Pole Mount
I want to relocate my AT-9 KaKu 5-LNB dish.
It's currently mounted on the roof of my 2-story house. I was never a
big fan of locating it there because of high winds in this area, but
at the time the installer said that was the best place. Oh well, live
and learn - I've already had to climb up there and realign it twice
due to winds.
Anyway, I want to relocate it off to the side of a deck I have and
mount it onto a mast, into a concrete base. I've called Ironwood
Communications (the local installer) to inquire what is needed and
they say it --has-- to be a 2" OD pipe.
The local big-box places (Lowe's & Home Depot) only have back iron or
galvanized plumbing pipe and galvanized electrical conduit - the
closest sizes being 1-1/2" - that's 1-1/2" ID and 1-7/8" OD. I even
called a couple local fencing contractors and that's all they have
too. Fence posts also tend to be thinwall.
The question is; will 1-7/8" OD suffice? I can't seem to find any
heavywall pipe that's -EXACTLY- 2" OD anywhere.
Any ideas?
KA/KU Pole Mount
due to winds.
Any ideas?
Hey, you get around! I saw your post on the newsgroup alt.dbs.directv (I think). Anyway, you can get 2" pipe at a good fence company. Be aware that the pole may be slightly smaller than 2" and you need to tighten the dish very securely to the pole. You may want to put a set screw in the pole, also. Good luck!
KA/KU Pole Mount
due to winds.
Any ideas?
No, you MUST use 2" OD pipe, otherwise it will not tighten properly...
Yes,
Go to the fence company and get the 1- 7/8"
Get the heaviest they have, make sure it's not the Sch. 20 as that will not work.
I have sch. 40 Galvinized fence post, 16' buried 30" in concrete, with a bolt thru the end to prevent any turning in the future.
This works great, it is a slight bit small (1/8") when setting up the pole make sure it is plumb, place the mast over the poleset up the dish, when it's where you want it, place a self tapping screw thru the mast into the pole , this will keep it in place as well as tighting the normal nuts and bolts
as well.
Mine has been this way for over 2 years now and have never had a problem with it.
Jimbo
Wouldn't be MUCH simpler just getting the 2" pipe - it would sure seem so to me, especially when it comes to peaking on those Ka birds; but to each his own I guess...
Thanks all - I found a local fencing contractor and bought 8' of 2" galvanized HW (sch 40). OD is reeeal close, like 1-31/32" - close enough.:D
Now I get to teach my teenage son what a post hole digger does.:D
:D:D:D
He won't get much of a education, you only need 1 hole and anywhere from 24-36" deep, depending on your area, should take. what, all of 5-10 minutes ?
Jimbo
Thats thin wall, I would not use that, although I know they do,do it. That looks like no more than fence pipe.
Jimbo, do you think if he filled that pipe with concrete he'd be OK?
I'm in the same boat trying to find heavy gauge 2"OD pipe.
stumo
stumo
Again, head to your local fence company. They should have 2" thick wall posts.
I found 2" od pipe readily available at electrical supply houses..
I hadn't thought about electrical supply places, thats a good thought ,if you don't need a license to buy there, I'll have to keep that in mind.
Is it heavy gauge ? The thin wall stuff I would not advise using.
Jimbo
Jimbo
nahh...Every one is differnt though.. I needed a length (10') of threaded conduit. I told them I was in the satellite business and they were more than happy to sell me what I needed. They even cut it to length for me. Granted, some supply houses will not sell to the general public. But in my experience most will.
And yes it is sched 40..Thick walled stuff.
Thats a very good catch, thanks again, I hadn't even thought about them, but they probably have plenty of it.
I used a 16" piece from a local fence post place, sch 40 galvinized. Works great.
I wonder what kind of price the electrical supply place charges.
I got mine and the concrete for under 40-50 bucks.
Jimbo
Jimbo
It wasn't cheap. I think the length was around $18.
I needed it. But I passed the expense along to the customer. I am paid as though I were a contractor so I have to buy my stuff.
I did pay contractor price. Buy in smaller quanitities and the price is higher.
And it's cheaper than the big box stores.
So could you do a 16' price and concrete, under $ 50 ?
If so, I'll recommend it to others as well.
Jimbo
Changing Programming
Birdog not finding dtv 101
