Move Dish from 61.5 to 77
HoodlumKY
42
5
TN
So, I currently have a dish pointed at 110/119 with a wingdish at 61.5. From what I'm reading, my locals (Paducah, KY) will most likely be on 77.
Can I just move my 61.5 and point to 77? Will I be losing anything from 61.5? It looks like most everything on 61.5 is on 110, but it says spotbeam instead of ConUS. So, I'm just a tad concerned on what I need to do to get ready.
I just have the silver HD package, no addons.
Thanks much
That's where I started looking. From what I see, ESPN2, HIST, A&E, FX, etc are on both 61.5 and 110. I'm more worried about what I will miss by re-aiming to 77. Basically, what is on 61.5 that is NOT on other other 3 (110/119/77). I'm not finding an easy way to see that info.
Most of your HD programming comes from 61.5 (including what you listed), all the SD versions are on 110/119.
The column next to the channel name will tell you if it's the HD or SD feed.
You will either need a EA 1000.4 dish or WA 1000.2 with 77 wing dish.
61.5, 72.7, 77 then 110, 119 & 129
You will lose 95% of all your HD If you need to go to 77 for LIL then you need 61.5,72.7, & 77 to match what you have now. The EA is the previous listings then what is know as WA is 110,119, & 129. 61.5 and 129 have basically the same programing.
Bummer
Thanks much for the info guys. I guess I need to get a new setup. I better hop on this quick, though, since my locals are coming SOON. ;)
Yes, I have a 622. Thanks for the heads-up, though.
So, I'm guessing I can't just re-aim my Dish 500 DPP at 72/77, right? Angles and what-not would probably not match up. I know, wishful thinking right?
Would just like to not buy more equipment if possible.
Evansville Paducah Davenport Delay?
What is a good OTA antenna for 722k ?
