I have a Dish 500 with a legacy dual LNBF. Each LNBF has two coax ports.
Question 1: Can I run four receiver boxes by using the four ports?
Question 2: I just purchased a Pico Macom Tru Spec TSMS2150-4A 3X4 multi switch (40-2150 MHz). One input is "LNB A 13V/14V" and the other input is "LNB B 17V/18V". It has four outputs. It seems that each input must be connected to its own LNB, so if I simply connect either LNB to port A, and the other LNB to port B, will that correctly allow for up to four receivers?
If I'm correct, either of the above methods should allow me to run up to four receiver boxes.
Any comments?
Any comments?
