NE1 recieving HD locals from Louisville, KY??
blur2u
12
I currently live in Bardstown, and I was wondering if anyone is receiver OTA HD in that area....I don't want to buy an antenna if I can't get a signal!
Thanks,
Sam
Zip
My zip code(where I live) is 40004. I am not sure what the zip code is for Louisville.
The Louisville towers are about 40 miles NNW of you at 338 degrees. All are UHF except WBNA-DT which broadcasts on ch 8. Digital frequencies are ABC 11.1 on 55 back to 11 2/09;CBS 32.1 on 26; FOX 41.1 on 49;NBC 3.1 on 47; Independent 21.1 on 8.
If you are not down in a low spot, and you use a good antenna such as the CM 4228 you might have a good chance. The 4228 is not good on ch 8 but if you do not need it. Also ABC is going back to ch 11 by Feb 2009 - might be an issue, but the 4228 is better on 11 than 8.
From 2 miles north of Bardstown here is what's available. Your reception will depend on the exact location of your house. The correct antenna is a Channel Master 4228 with a preamp such as the 7777. It will have to be on the top of the roof, perhaps with a 10' mast. You will not need a rotator for the main Louisville stations, they're all within 2 degrees.
To see for sure, type your address into www.antennaweb.org .
* green - uhf WLKY-DT 32.1 CBS LOUISVILLE KY 334° 41.8 26
* green - uhf WHAS-DT 11.1 ABC LOUISVILLE KY 332° 41.6 55
* green - uhf WDRB-DT 41.1 FOX LOUISVILLE KY 332° 41.3 49
* green - uhf WAVE-DT 3.1 NBC LOUISVILLE KY 334° 41.8 47
* lt green - vhf WBNA-DT 21.1 i LOUISVILLE KY 313° 21.1 8
* red - uhf WBKI-DT 34.1 WB CAMPBELLSVILLE KY 182° 21.3 19
* red - uhf WKZT-DT 23.1 PBS ELIZABETHTOWN KY 246° 23.7 43
* blue - uhf WFTE-DT 58.1 UPN SALEM IN 332° 41.3 51
* violet - uhf WKMJ-DT 38.1 PBS LOUISVILLE KY 334° 41.8 38
* violet - uhf WKPC-DT 15.1 PBS LOUISVILLE KY 334° 41.8 17
Do you know of a list what channels change in 2009?
ralfyguy
my fingers are killing me typing this list for you.
edit/find next-enter a city or station call and search to yar hearts content.
Current DTVChannel
Current NTSCChannel
Tentative ChannelDesignation
example
wstm syracuse
54
3
25
  • DA-05-2649A2.txt
Rick0725 said:
ralfyguy
Current DTVChannel
Current NTSCChannel
example
wstm syracuse
54
3
25
Thanks for the list, and sorry about your fingers, makes me feel bad now. But this is very kind of you. I owe you one!:up :up :up :up :up :up :up :up :up
