New Dish 1000.2 install with VIP622 receiver
twilliams8
Hi everyone,
I setup my new dish 100 and peaked at 119, I then was able to connect to 129 and 119, but no 110, I played around with the aim and was able to hit 110, but now I have only 110 & 119, I lost 129, I have tried to move it back and forth, checked azmiuth, elevation and skew, I can reboot further west and get 129 again, but no I don't have 110 or 119, I move the dish back 10 degrees and I can get 119 again and when I peak from there, I get 119 & 110 back, but I lose 129 again. I try moving it slowly little by little, but no luck, I have also ran check switch everytime I have made changes. I am at a loss, any ideas?
You are getting the sats with the wrong LNBF's pointing at it. That is your problem. When looking at the LNBF's from behind the dish, then the one on the right is for 110, and the one in the middle is for 119, and the one on the left is for 129. Cover the two outer ones with aluminum foil and then try to get 119 with the one in the middle. Once you found it, you should have the others too, given that your skew and elevation is set correctly.
Anyone who watches TLC-HD
How to find subcontractor to install dish and wire house
