New Hopper Installed - Networking Question
mbuchsbaum
Hi all! Thanks for checking this post out. I had a Hopper and Joey installed for the first time yesterday and after about 2.5 hours everything's up and running. We ran into a problem with the Internet connection and ended up using the Wi-Fi adapter, but I can't figure out why. Here's the scenario and steps tried:
  • Had a hard-wired CAT-5 connection to a router working fine with DirecTV
  • Installer and I tried that same cable in both the top and bottom Ethernet ports on the Hopper (Didn't work)
  • Tried a new CAT-5 cable to a different port on the router (Didn't work)
  • Tried that cable and router port into a laptop which worked fine
  • Tried a second new Hopper from the truck (Didn't work)
  • Tried the USB Wi-Fi adapter from DISH (Worked!!!)
So I'm really confused here and need to do some digging this weekend. In a nutshell, everything we tried using a hardwired connection failed, but the Wi-Fi connection worked. Any ideas?
Thanks!
Sounds like an auto negotiation issue indeed. I would try a crossover cable into the laptop and see if it links. That should autoneg properly at 100.
Sent from my iPad using Tapatalk
Bad ethernet on the Hopper, perhaps? If they wifi adaptor works, I wouldn't sweat it. Though it would nag me that there's possibly something wrong with the Hopper's hardware.
Has there been any issues with Sat 119 and 129 since solar flare
DIRT Help -- Restore from remote control?
