Old Hopper 3 making loud pops
Mark609
SatelliteGuys Guru
131
41
Texas
Help! Double pops, quite loud, are driving me crazy on my Buckeye Hypex NCx500 3 channel amp, only on DISH sources. 7.2.4
Every time the program source changes from a commercial back to a program or vice vs I get 2 loud pops. Where it was once occasional, it's now all the time. Kicker is I did not have these issues with previous external LCR amps/pre-amp out nor the internal A/B amps in my Anthem MRX1140 that was driving LCR a while back.
DISH Tech stayed with me on the phone linking my unit to them about a month ago but it didn't help.
Beginning to think I've got a bad unit or is a software update issue?
Am using new 1.5' Monoprice XLR->RCA cables.
That double pop when transitioning between a commercial and the main program usually points to an audio format handshake lag. When the Hopper 3 switches audio streams—like moving from a standard 2.0 PCM commercial block back to a 5.1 Dolby Digital program stream—the digital audio lock drops for a microsecond.
If your AVR or soundbar doesn't mute fast enough during that transition, or if the aging hardware on an older Hopper 3 passes a sharp unmuted spike through the HDMI/Optical line during the handshake change, you get those exact loud pops. Since it went from occasional to constant, a few things are worth checking to narrow it down:
  1. Test PCM Mode: Go into the Hopper 3 settings under Settings > Audio > Digital Audio Output and temporarily change it from Dolby Digital / PCM to PCM Only. If the popping stops completely, you know it's definitely a format handshake glitch between the Hopper and your sound system during stream transitions.
  2. Audio Delay Toggle: Check your soundbar or AV receiver settings to see if there is an option for audio delay, lipsync, or an audio format lock mode. Sometimes introducing a tiny delay or forcing a static format handles the transition smoother.
  3. Hardware Aging: If it still does it in PCM mode, it could unfortunately be internal. Electrolytic capacitors in older Hopper 3 units degrade over time. When they start failing in the power or audio output stages, voltage instabilities manifest as line pops during rapid source and bitstream changes.
Are you running your audio via HDMI directly to the TV, or using Optical/ARC out to an external soundbar or AVR? Sharing your audio path might help narrow down a workaround.
One thing that stands out is that this only started with the Buckeye in the chain — you did not get it with the previous external amps, or with the Anthem's own amps driving the LCRs. The Hopper's output has not changed, so that points more at the new amp chain than at a bad Hopper.
Almighty1's PCM test is worth doing, and if the pops stop in PCM it is the format change between the program and the commercial doing it. A few tests that would narrow it further:
- Swap the left and right cables between the Anthem pre-outs and the Buckeye and see if the pop moves to the other side. If it follows one cable, that cable or adapter is the suspect.
- Run a different source, like a Blu-ray player or streaming box, through the same Anthem pre-outs and the same Buckeye channels, and play something that switches audio formats. If that pops too, the Hopper is off the hook.
- Try the Hopper on a different HDMI input on the Anthem, just as a test, and also try the Hopper's optical output to the Anthem if you have a cable handy.
Does it happen on recorded shows as well as live TV, and on every channel, or only some? Turn the volume down while you are testing — those pops can be hard on tweeters. Let us know what the cable swap and the other-source test show.
Dish 4K Event Listings (No Discussion)
Updated to H715 on a Hopper 3 from H713
