"Pink Screen" on startup - HR20-700
winesmile
19
Another weird problem with an HR20....
Sharp LCD connected via HDMI
After the receiver's been powered down for a while (a day) and you power on the TV/Receiver a pink screen appears for about 60 seconds. No audio/video... Then picture comes up and everything works fine.
I've switched sources during this 60 seconds and they all work - elimination the LCD as the problem.
Anybody had this problem? I'll change back to Component, but would love to keep the HDMI.
:welcome
It's a handshake issue with your HDMI/TV set connection....contact the TV maker to see if they have a solution or suggestion...if it is too bothersome for
you, then component is your only solution.
I've had a similar problem.. When I turn mine on, it has a pink hue to it sometimes.. All I do is turn the tv and reciever off and back on, and it's fixed. Sometimes if I turn channels up and down it fixes itself too..
I'm not too worried about it..
Please HELP with Issues I have
NHL Network HD Is Up!
