Question about my Coaxial Cable
no25
24
Stevens Point, WI
I bought Some Magnavox RG6 Heavy Duty Quad Shield Coaxial Cable from Menards and I just read on the spool (That it is For In The Wall Use) does this mean I can't use it outside?
Ivan
Probably mainly to mean that it is not for burial. I have seen cables labeled "indoor" and "outdoor" but haven't seen one labeled "in the wall" yet.
I would guess that any cable labeled for outdoor would have an outer jacket better able to withstand the extremes of weather and sun than an indoor, or in the wall, one.
I use either outside but always make sure you use weather proof connectors.
"In the wall" use labeling means that it meets minimum NEC/NFPA requirements for wiring run through walls as opposed to laid on the floor or tacked to the wall. It is a fire-spread potential issue. If you do some home theatre or sound wiring in your house and you run the wires between the drywall, it better be rated for "in the wall". Otherwise, you could have a very expensive and time consuming removal or replacement project when you try to sell your house. A "home inspector" will deem the installation, not fire safe.
Unless it has some UV protection you may have problems later caused by the sun. Also unless it is direct burial cable avoid underground use and do not place it in your rain gutters.
Dish 721 problem - lost lock
VOOM Spinoff Delayed Till 4th Quarter
