RE: [VOOM] OTA problem in Tyler, TX
W
Willis,Joshua Ray
Guest
So I got my voom installed in March. OTA has never worked. I figured that
it was because the local NBC station wasn't broadcasting with enough
wattage, so I just ignored the problem. Now my town (Tyler, TX) also has a
CBS station that's broadcasting in HD. Even though the tower is only a few
miles away, I still couldn't pick it up with the antenna they installed. To
test it out I went to Best Buy and bought a little indoor HD antenna and
hooked it up to the OTA reciever on my Voom box. CBS came in fine. Anyone
have any suggestions, or should I just call Voom and get them to send
someone out again?
Joshua Willis
Regional Systems Specialist
Texas Health and Human Services Commission
Due to HHSC consolidation efforts, this e-mail address has changed; please
update your e-mail address book accordingly.
------------------------ Yahoo! Groups Sponsor --------------------~-->
$9.95 domain names from Yahoo!. Register anything.
http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
someone out again?
Joshua Willis
Yahoo! Groups Links
I'd call voom and get a service call.
Robert
_____
From: Willis,Joshua Ray [mailto:joshua.willis@hhsc.state.tx.us]
Sent: Wednesday, September 08, 2004 1:14 PM
To: VOOM@yahoogroups.com
Subject: [VOOM] OTA problem in Tyler, TX
someone out again?
Joshua Willis
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129oa6mlt/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705036932:HM/EXP=1094753657/A=2319498/R=0/SIG=11thfntfp/*http://www.
netflix.com/Default?mqso=60185352&partid=5285298> click here
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=
:HM/A=2319498/rand=586065003>
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
<mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
Robert
_____
someone out again?
Joshua Willis
ADVERTISEMENT
_____
Yahoo! Groups Links
You can rescan your OTA channels.
At your own risk.!!! But I have done it with no problem.
First, is your off air antenna hooked up to the plastic module on the right side (looking at the back) of the back of the VOOM receiver. This is where your OTA antenna needs to hook up to.
Then hit VOOM button, then green button in row 3 of buttons. Then arrow down to 4th item System Settings and hit OK to select that. You will get a caution at this point....
Then, assuming you have 6.20 software, and you should if you've been hooked up to VOOM every night. The third and last number in the 2nd row (or third can't remember) on the upper right will say 6.20, then you are OK.
Now hit Installer menu. Go to Scan OTA channels and let it scan the whole thing, about 2 minutes. It should list what channels were found. If nothing was found then you have a connection, hookup, or antenna aiming problem. If channels wer found then hit watch button, press the number 2 and start channel surfing. All two digit numbers are the OTA ones.
If you have any doubts about doing this call VOOM aqnd get a service call. Do you get any SD channels currently on your TV with yur antenna?
I am only going from memory so read the commands carefully before proceeding. It is a very simple proceedure and you are not likely to hurt anything by doing it.
----- Original Message -----
Sent: Wednesday, September 08, 2004 11:14 AM
someone out again?
Joshua Willis
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service..
[WILT] Help this new Voom customer out...
V
[VOOM] New file uploaded to VOOM
