recording with 211?
The 211 currently supports up to 2T, no larger. And yes, go with WD.
Reactions: Tampa8
I'd stay well away from mechanisms that use third party OEM drives (Iomega, Fantom, LaCie, etc.).
Don't assume you're somehow enchanted and can ignore thomasjk's advice about using self-powered drives.
Amazon is offering the Seagate Expansion 1TB drive for $78 and this should provide you with a good baseline for comparison.
Reactions: navychop
I use both a 500GB WD in 1 211 and a 1.5 TB Seagate Expansion in the other 211. Both work fine. I had 2 500GB WD until I dropped one while rewiring for new tv and it died. I had the Seagate on hand, so I used it
i just purchased a
WD 1TB WD Elements Portable USB 3.0 Hard Drive Storage (WDBUZG0010BBK-NESN) from amazon and i want to make sure it will work with my 211.i read where dish will accept 1 tb but it has to be a single platter drive. does anyone know if the one i got will work?
i just purchased a
No it will not. You can't use portable drives. Its needs an external power supply
edit: late to the party, replies didnt show up in the post when I opened it
Is the usb cable a 3.0 cable? Sometimes when they say 3.0 they are referring to the cable connector.
Question is does it have it's oiwn power supply.
Don't know about the 211 but I know from experience that the Hopper will support a 3 tb drive.
Max for 211 is 2T.
Do i need a Hopper?
Intermittent problem, Dish support no help
