Remote code for Samsung SIR-TS360
TDOGGY
7
I have a Sony RM-AV2500. Does anyone know of a remote code for the Samsung HD Receiver? (SIR-TS360)
Sony reply to request for sir-ts360 remote code ...
This was the response from Sony on the code for Remote Commander RM-AV2100 ...
Thank you for contacting SONY Online Support.
Regretfully, the codes are not available for the Samsung HD Receivers.However, the RM-AV2100 has a learning feature that can control almost any infrared component, provided the components original remote is available to teach the RM-AV2100.
The following are the steps for USING NON-PRESET REMOTE CONTROL FUNCTIONS for the Sony RM-AV2100 Universal Remote Control:
To operate non-preset components or functions, use the following <learning> procedure to "teach" any of the programmable buttons and keys to operate the functions of another remote control.
NOTE: Some specific remote control signals may not be learned
Example: To program the PLAY signal of your component to the VCR1 (PLAY) key of the RM-AV2100:
1.. Place the RM-AV2100 head to head with your component's remote control.
Make sure that the remotes are approximately 2 to 4" away.
2. While pressing COMMANDER OFF, press the Component Select button for the component whose signals are to be learned.
"LEARN" appears and all the learnable keys flash.
The "C+C-V+V-MU" display indicates if CHANNEL +/-, VOLUME +/- and MUTING buttons are
learnable or not.
Example: COMMANDER OFF button + VCR1 button
NOTE: On the "flashing" display: The keys or buttons that are already preset for that component flash twice while those that are not preset flash once.
3. Press the key or button on the Commander you want to "teach".
"LEARN" flashes and the only pressed key remains on the display.
To teach on the CHANNEL +/-, VOLUME +/- or MUTING buttons, press the corresponding button. "LEARN" flashes and only the pressed button remains indicated on the display ("C+", "C-", "V+", "V-", or "MU").
4. Press and hold down the button on the other remote control until you hear a beep.
(If you release the button before you hear a beep, the signal may not be learned correctly.)
"LEARN" stops flashing and stays lit. When the command has been learned successfully, the learned keys stay lit and the other learnable keys flash.
NOTE: If "NG" flashes on the display, learning did not succeed. Try steps 3 and 4 again.
5. Repeat steps 3 and 4 to teach functions to other keys or buttons.
To LEARN another components remote control signal, after positioning the two remote commanders as in Step 1, press the corresponding Component Select button, then follow steps 3 and 4 on the left to perform learning.
6. Press the COMMANDER OFF button.
NOTES: If you do not perform learning steps within two minutes, learning mode ends.
If you do not perform step 4 within 10 seconds after step 3, the display turns back to the
display in step 2 (all the learnable keys flash). In this case, perform step 3 again while the
display is flashing.
If "NG" appears while learning, the memory is full. To free memory, clear learned functions
from keys that you do not use often (page 20). Then continue the learning steps.
If you touch a key by mistake in step 4, while pressing the RESET key, press the mistaken key.
Then repeat from step 3 to continue learning.
NOTE: In some rare cases, you may not be able to operate your non-Sony equipment with the supplied Remote Commander. This is because your equipment may use a code that is not provided with this Remote Commander. In this case, please use the equipment's own remote control unit.
Thank you for the opportunity to be of assistance.
The Sony Internet Support Team
Online Support and Services Center
SSSM
Sreedhar
HD package pricing
