reset-hard drive temperature-722
powerhouse1960
290
indiana
Is there a way to reset the high -low average temperature in the diagnostics of the vip 722.
Thanks for any replies
I don't believe so. You could try to do a full factory reset (menu 6 6) but that will reset everything and I'm not going to try as I don't want to have to redo everything. Sorry.
Press Menu-6-3, then Info-right-left-TV/AV, confirm corruption with Select. Escape out with LiveTV. Press and hold Power button on receiver until it reboots. This will reset all counters and some user settings. You also have to rescan OTA stations if applicable. You will have to redo the Guide view and CC setup, as well as output resolution. You need to redo the recordings layout with what groups the recordings go to. But the groups will not be deleted. It will not delete timers, and not the check switch. This is actually an NVRAM reset. I do this all the time, as my 722 reboots often without warning.
722/622 Tuners Could be Smarter
Saving 622 timers possible?
