Run Tivo off of DTC-210?
Cobra5wood
16
St. Charles. Il.
I have my RCA DTC-210 run thru my receiver(B&K 505AVR) via component connection for my Directv service. Will either SD or HD(as SD?) also pass simultaneously thru the S-Video output if hooked up to a Tivo?
:welcome
:welcome
It does pass through to S-video, RF(ch3), and composite video. Its not perfect though. If your monitor is 16:9, it will squeeze what you see onscreen to fit 4:3. Not entirely bad, because you can output the recorded image to FULL and see a fairly close image to the original. HD signals get cut and distorted a little, but SD signals look pretty good. I have found that 720p feeds cutout sporadically every few seconds on my S-VHS. Just experiement and you should be able to get something.
can someone tell help me out
D* HD upgrade question(s)
