SageTV and Skyvision
49studebaker
71
1) Open SageTV. If you are using version 6, you will need to manually import the "ImportExportChannelLineup.stvi" file. If you are using version 7, you can install the Import/ExportChannelLineup plugin from the plugin manager.
2) In SageTV, select your Video Source and then in the Channel Setup, under the "Edit Channel Lineup", select "Import Channel Lineup".
3) Look in the SageTV directory for the file generated in the previous step. Replace the file name "video_input_device_name.import" with the name of the video input device.
4) In SageTV, select "Import Channel Lineup".
5) The Skyvision channel lineup should now be imported into SageTV
dual LNBF
Trying to position a 7 foot dish for sat @ 72
